over reved
If you down shifted and the RPMs spiked above 9k, you COULD be in trouble. If you really have the ears of a cheetah and it only went to 92 or 9300rpm, then you're fine. But I expect you don't.
With the AP1, external signs of damage from an over-rev might not show up until much, much later (at which point it's too late because you have just dropped a valve). You need to pull the valve cover and check the retainers for damage now and again in ~5k. You don't need as gasket kit.. it's rubber and should be in fine shape.
Originally Posted by chad86,Aug 12 2009, 09:57 AM
Your car should be fine.....I've hit rev limiter many times
VC gasket should be still good, i pulled mine about 5-6 times and still rocking the same one with great success.
after my over-rev, compression and leakdown checked out fine...but 8 months or so later, i had bad compression and leakdown numbers...had to service the head for warped valve guides.
can't explain it...just an fyi.
Get a flashlight and a dental / automotive mirror and check the underside of the retainers. If they are cracked they must be replaced. If anything has happened it will most likely be on the intake side.
If the retainer is cracked, the cotters will become dislodged as the retainer walks up the valve stem. This will make a small wear mark on the valve stem and eventually cause it to break. When mine broke the very tip of the valve stem and the cotters were still stuck in the retainer.
Originally Posted by rob.ok,Aug 19 2009, 12:04 AM
^ Might be a bent valve. Really sorry to hear. Hopefully you have friends that can help out.
I'm going to pull the valve cover tomorrow and check the valve spring and everything else, if something is damage i should be able to see it right?
