over reved
Originally Posted by s2guru,Aug 19 2009, 12:07 AM
i know, after reading a lot of topics on the subject , here on s2ki. i went outside and checked the spark plug , they are fine ( according to some pictures i saw ) destroy spark plugs = new engine.
I'm going to pull the valve cover tomorrow and check the valve spring and everything else, if something is damage i should be able to see it right?
If the piston and the valve hit causing the valve to bend, your gonna have to pull the head to get a better idea of what type of damage you got.
No matter what you need to change the retainers now and hopefully that is all. Pulling the cams is a very easy job to do and will allow you to investigate much easier. Once the valve cover is off its only a matter of minutes to pull the cams and rocker arm assembly.
Rocker arm install tip; Remove the cams and flip up all of the rocker arms on one side. Get yourself some small rod or all thread and wrap them in tap and place them in the cam journals then flip the rocker arms back down so that they rest on the rods while you set the assembly back into the head. This will make your life a little easier.
