OVERHEAT!
Old Oct 7, 2009 | 01:45 PM
r_duff's Avatar
Default OVERHEAT!
Hi guys,
I got this problem... my car would spontaneously overheat from time to time, regardless of the weather. I noticed that when the car is in overheat-mode, the heater does not blow hot air, as if the coolant is not cycling. After a few minutes of driving though, the temp goes down and the heater starts blasting hot air again... When this first happened, i turned off the engine and noticed that the reservoir under the hood his close to the brim, way past the 'max' mark on the bottle.
I've already replaced the stock thermostat with a mugen unit and changed the coolant and bled the system. Any ideas? Waterpump??
Old Oct 7, 2009 | 01:55 PM
rob-2's Avatar
Are you certain the system is properly bled?
Old Oct 7, 2009 | 02:10 PM
Fast Jack's Avatar
dejavu' U described it to a "T" dos bubbles oonda cooling system.If ya skip down a few posts there is a discussion on this very problem and how to fix.
Old Oct 7, 2009 | 04:15 PM
r_duff's Avatar
this one huh?
https://www.s2ki.com/forums/index.php?showtopic=735344
whats weird is that this happened before i touched the cooling system. it was all bone stock when this happened... how did air get in the system all of a sudden? Car is daily driver for 7 years, 80 miles round trip every day. didnt have this issue until last week!
i guess ill try rebleeding with the front jacked up
Old Oct 7, 2009 | 09:13 PM
Fast Jack's Avatar
Originally Posted by r_duff,Oct 7 2009, 04:15 PM
this one huh?
Good question,how did air get in the cooling system. Just a couple of guesses: rad cap or maybe one of the bleeders was snugged tight?? U got me curious,let us know what u find out.Super Negcamber is the man,bet he would have some ideas on this.
Old Dec 10, 2009 | 10:18 AM
MrxKvn's Avatar
I have the same problem. Car overheat and the heater is not blowing warm air. When I open my hood the reserved tank for coolant is way pass the MAX line. I tried bleeding it and that didnt work. Any suggestion on how to fixed the problem? Where is the thermostat located?
Old Dec 12, 2009 | 07:12 PM
fatjoe10's Avatar
Reservoir tank past the max mark means a blown head gasket. Compression is leaking into the cooling system and pushing coolant out the bottle. Stop driving and get it checked .
Old Dec 13, 2009 | 03:07 AM
Claus's Avatar
sounds like blown head gasket to me as well....
Old Dec 14, 2009 | 02:07 AM
MrxKvn's Avatar
How much would it be around to replace the head gasket with labor?
KaNgArOo
Nov 24, 2014 12:23 PM
GaFilka Fish S2K
Jacksonville
Oct 17, 2014 07:03 PM
yorkies2k
Nov 15, 2013 11:24 PM
r_duff
36
Oct 31, 2009 03:46 AM
DOUGHS2K
Nov 16, 2005 07:22 PM
