overheated with no warning
Old Dec 11, 2008 | 09:31 AM
newbos2k's Avatar
Default overheated with no warning
So the other night I was driving home and all of a sudden there was smoke/steam coming from the tranny tunnel, and under the hood, i looked at the temp gauge and it was at 3 bars. the car instantly shut off, so i veered off and had it towed home. upon inspection, I noticed the bottom rad hose had a hole in it and the cooling system was bone dry. This puzzled me that the gauge didnt alert me to the over heating. So i prayed, I fixed the bottom rad hose, filled it back up and tried to start.. the motor triedto turn but couldnt catch, so I decided there was probably more damage, I did not attempt to crank again. I drained the oil and it was filled with what looked like bearing material. Now the head is off the engine, my question is there any chance the block could be salvaged from this type of abuse it handled? the crank still turns freely.
Old Dec 11, 2008 | 06:50 PM
Kirpich's Avatar
You probably need to pull apart the rods and inspect the crank. If it's not scored, and the bores are good, you can probably just get new main and rod bearings.
Then take the block and the head to a machine shop and check the deck and the head for warping, you might need to re-deck it. Then a new headgasket, troubleshoot the cooling system gauge, and you might be ok.
Old Dec 12, 2008 | 06:22 PM
CKit's Avatar
Oh sucky. Hope things work out.
RorySum
Oct 14, 2016 03:02 PM
Car Analogy
Dec 7, 2014 07:20 AM
s2kt3
Nov 5, 2012 09:31 PM
seouljahone
May 9, 2007 03:45 PM
chrisesteban
Sep 27, 2006 11:53 PM
