overheating problems
Old Apr 19, 2013 | 09:09 PM
La Lunatika's Avatar
Default overheating problems
hope u can help me since I don't know what to do...
my car is overheating and no codes that can tell what could it be...It's an AP1 '02 (105,XXX miles)
I bleed out the car, the fans turned on, radiator cap in tighten, the reserved tank is fill...
I remembered... two times happened that the reserved tank was empty so I though that was the problem but no... still overheating
each time a bleed out the car throws a lot of air... am I doing something wrong?
could it be the water pump or the thermostat? can be getting air by other place?
P.S. my English is not perfect sorry if I write something wrong
edit: I just ride the car and see a line of water between point A and B but don't hear any noise
HELP!!
Old Apr 19, 2013 | 10:41 PM
franky's Avatar
try changing out the thermostat
Old Apr 19, 2013 | 11:05 PM
s2cho's Avatar
Thers a leak somewhere and air is getting in the system. Do you see any drops of coolent on your drive way/garage?
Old Apr 19, 2013 | 11:55 PM
forgot to put that... I don't see any obvious leak :/
question
in case it was a bad water pump should I buy the OEM or an aftermarket?
jdmdohcpower
Oct 5, 2014 08:55 AM
Allday
Jan 8, 2014 03:23 PM
Spec_Ops2087
May 29, 2010 01:22 PM
krazik
Jan 3, 2009 01:28 AM
NAREKS2k
Jan 28, 2008 01:41 PM
