Overheats when accelerating
Old Jun 7, 2018 | 11:48 AM
dim85's Avatar
Spammer
Default Overheats when accelerating
Hi people as the title says my car started overheating(4bars ap1) when the other day i was slight uphill with ~90m/h cruising i would say.
Slowed down a little and 3 bars again. After an hour i started it again and went to check it. Same story 4 bars after some hard acceleration i pushed some more and saw 5th bar for 2-3 seconds as i stopped it fell to 4th and after 10seconds 3rd again so i stopped pushing it and drove
Old Jun 7, 2018 | 12:11 PM
toztigger's Avatar
are you leaking coolant? do you have coolant in your over flow? do a bleed, ensure no air, look for cracked pipes and leak, especially wet stains on hot parts
Old Jun 7, 2018 | 12:17 PM
dim85's Avatar
Spammer
Checked for leaks from first insident didnt found any nor coolant missing the other day from first overheat. Im thinking to do a comp test just so i can sleep at night cause i shit my pants when i saw 5th bar. Then if its ok ill try to flush the rad from these lentil-like inside that seem to have formed in the passages
Old Jun 8, 2018 | 04:18 AM
toztigger's Avatar
yea i dont know what those are they seem pretty weird, just flush with water until coolant comes clear, than just drain following billmans method
Old Jun 10, 2018 | 11:54 AM
zeroptzero's Avatar
Wonder if the little beads are hard deposits or gelatinous ? Hopefully they aren't sitting around the thermostat. For the relatively low cost of a nice aluminum rad I'd probably swap in a new Koyo rad.
To get it perfect you could remove the thermostat, block coolant plug, and then give it a good flush iwith high pressure water from a garden hose. It is a bit of work to remove the thermostat but worth checking if it continues to overheat and the rad flush doesn't solve the issue.
7smurfs
Aug 16, 2018 12:19 PM
dim85
Jun 7, 2018 02:49 PM
jimi
Jul 18, 2013 08:44 PM
jakestr
Jan 11, 2011 03:47 PM
Boost76
Aug 6, 2010 07:43 PM
