p1399
Old Jan 21, 2008 | 11:07 AM
Sargeant Handbag's Avatar
Default p1399
The car only misfires at idle it seems. (if i rev to 1k it will not miss a beat) The car ran a 13.798 @ 100.1 mph completely stock with this problem so I dont think its misfiring above 5900 rpm. The CEL only comes on when the car has set and idled for more than 5 mins. Not always either. It does seem to run kind of rough at about 800 rpm it will then also sometimes run bout 900 and seem fine just to idle for a while and start running 800 with noticeable mis here and there. If I dont clear the code it will go off on its own and prob come back on again in 10 days.
I did search couldnt find nething non consistent like this.
Thank you guys for your help in advance.
Old Jan 21, 2008 | 02:15 PM
CKit's Avatar
Nice screen name.
Old Jan 21, 2008 | 03:51 PM
Eluded's Avatar
Idles rough? U can hope for bad plugs, bad wire, bad coil pack, bad injector but it could be the head ! If its an AP1 i'd rule out the easy items then focus on the non bullet proof, falls apart if you push it, Ap1 S2000 head.
Old Jan 21, 2008 | 04:22 PM
negcamber's Avatar
More than likely either injectors or coils...how many miles on the car?
Old Jan 21, 2008 | 08:17 PM
CKit's Avatar
Just as likely to be a spark plug (and that's a cheaper fix).
Old Jan 22, 2008 | 08:59 AM
jojipoji's Avatar
same prob with mine, turned out that it needed a valve adjustment.
Old Jan 23, 2008 | 03:12 PM
THank you for the input. The car has 36k. AP2 2.2L Ive put prob 15000miles on the problem, its not getting worse. Not making valve noise. Do you think that maybe the valves could be out of adjustment and no noise. How do I know if the head or valves are bad? Any other way than a compression test?. How do you check the coil pack? Wires all show .01 ohms. #4 int he back or front? Are these things warranty?
Old Jan 23, 2008 | 03:17 PM
jojipoji's Avatar
My car idled funny and shook when at idle. At all other times, it was perfect. Purred perfectly to redline.
Old Jan 23, 2008 | 04:02 PM
Eluded's Avatar
If i were you, I'd find a REPUTABLE S2000 deelor and bring the car in for warranty work, the car should still be covered.
Altho, please note last time i brought my car in for work they fixed one thing and broke two others...
Old Jan 23, 2008 | 06:03 PM
ehh! sounds wonderful lol!
can I say catch 22 Dealer Dont worry
DefSport
Oct 12, 2017 12:13 PM
Frank
May 6, 2014 06:27 AM
Imbruceyo
Dec 4, 2011 03:24 PM
AP2 Rob
Nov 30, 2011 08:16 AM
jdmb16crx
May 12, 2010 12:22 PM
