P1607 code (help)
Old Jun 9, 2011 | 03:18 PM
s2000_x's Avatar
Default P1607 code (help)
somebody around here it's selling me a s2000 for a very low price, the only problem it's that the car have the check engine light ON, i already read the code (p1607) and i was searching and i discover that it's a malfunction with the ECU, if i just buy a used ECU and swap with the one that it's not working do i will have the problem solved? or it may be another thing? it's a serious problem this code?
and my last question is: if i put another ECU do i have to take the car to the dealer or any place to reprogram the ECU to my car? or it's just plug and play?
please help me with this because i really like this s2000, thanks!!
Old Jun 9, 2011 | 05:57 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Low battery can set this code falsely.
Reset the light and see if it returns.
You cannot plug and play an ECU. There are ways around it, if you can get an original key with the ECU.
Old Jun 10, 2011 | 08:54 AM
s2000_x's Avatar
ok i will try that, thanks
Old Dec 30, 2011 | 09:51 AM
awild's Avatar
I have this code as well. Did the reset fix it?
c32b
Nov 21, 2010 09:32 PM
ce-ce
Dec 10, 2009 11:16 AM
PRedS2K
Apr 2, 2009 04:29 PM
MunkeyBoy
Jan 15, 2007 11:05 AM
tru
Oct 1, 2004 02:37 PM
