parking lights not comming on?
Old Mar 9, 2007 | 07:45 PM
Killship's Avatar
Default parking lights not comming on?
Wendsday I turned on my parking lights at night in my driveway and saw that they dont work... The back lights come on but the side markers and the turning signals dont eliminate (sp)... Is this supposed to happen? because I recall someone who took a pic and the lights were on.
Old Mar 9, 2007 | 07:46 PM
Mister Jew's Avatar
sidemakers dont come on only when ur using turn signals. The corner lights should come on though. are you cluster and dash lights coming on?
Old Mar 9, 2007 | 07:48 PM
Killship's Avatar
Yes... the dash and cluster lights are all on exept the "chan." button and the first top two lights on the AC controll (the thing that tells the air where to flow.)
Old Mar 10, 2007 | 05:30 AM
Killship's Avatar
nobody has an answer? this cant be!! the turning signals work...
Old Mar 14, 2007 | 09:46 AM
Subanez's Avatar
I noticed the same thing on mine the other night...
::shrugs::
I'm still new to the car, so I don't know what's "right" and what's not.
I'm curious to know too, though.
Old Mar 14, 2007 | 09:50 AM
silencertk's Avatar
well the turn signal won't light up and as far as the "chan" button -- could just be burned out.
So here's what i would to first ---> check your fuses. I'm not sure if the parking lights have seperate fuse but it never hurts to check. Then i'd turn wheel all the way in and unclip the plastic from the behind the headlight enough to get to the side marker bulbs and replace them to see if thats your problem.
good luck
Old Mar 16, 2007 | 07:25 AM
Killship's Avatar
Ive gone through the fuse box and looked at all of the fuse connectors and they dont say anything about parking lights. Just headlights and brake lights...
Semp
Oct 20, 2014 07:52 PM
crav3s2k
Jul 2, 2008 09:14 PM
darkfx
Mar 31, 2006 06:56 PM
NFRs2000NYC
Sep 16, 2003 10:13 AM
