pass side window not working
Old Mar 17, 2013 | 02:04 PM
s2kneub's Avatar
Default pass side window not working
i decided to finish gutting my car yesterday and completely removed the ac unit, the heater coils, dash and pass side airbag. when i was done, i only encountered one complication; at some point i disconnected the pass side window. my question is, does it get power via a throughput from one of the components i removed or do i just need to find the clip and reconnect?
Old Mar 17, 2013 | 02:14 PM
Slows2k's Avatar
Turn the main switch on the drivers door on.
Old Mar 17, 2013 | 02:18 PM
s2kneub's Avatar
already checked that
Old Mar 17, 2013 | 03:45 PM
mattstryfe's Avatar
If I am understanding you correctly you have the pass window power disconnected and the drivers switch will not properly work the window?
I had this happen when I was replacing my passenger side motor assembly.
I HAD to have the Passenger plugged in to get the Driver's side to be able to control it. There should be nothing else (aside from a fuse) that controls this. So if the window motor is connected up then I would check the fuses.
Old Mar 17, 2013 | 04:18 PM
s2kneub's Avatar
neither the switch on the pass side door or the master switch will work and all the fuses are fine. i just can't figure out where i would have disconnected it.
elkdaddy
Feb 22, 2018 06:10 PM
SATXCFP
Aug 31, 2015 04:57 AM
WarrenW
Aug 20, 2011 09:32 PM
mikdys
May 9, 2008 08:43 AM
S2Kinside
Jul 20, 2006 07:20 AM
