Passenger side window won't go up
Old Jun 27, 2005 | 07:01 PM
S2kRob's Avatar
Default Passenger side window won't go up
Hey all,
I'm installing speakers in my doors, and am working it all out on my passenger side first, so I have the door panel off on that side.
I am installing speakers with XTC foam baffles to protect them from rain water. The baffles are really soft and collapsable, so what I did was mount everything into the door for a trial fit. I then lowered the passenger window from the driver's side to see if it would hit the baffle or not. It did, it slowed ever so slightly about one inch from the end of travel.
So I took the baffle out to modify it to clear, but now it won't go back up. There's no click or anything. If I hit the down switch, I will get a click, but when I pull the switch up, there is no click or anything. It's like the signal is not getting through.
Any suggestions? To me it just seems like something needs to be reset - and I already checked the child lock.
Thanks for the help!
Old Jun 27, 2005 | 07:03 PM
S2kRob's Avatar
Oh, and the force to collapse the baffle is absolutely miniscule. You basically breathe on them and they collapse.
How do I put the window up manually, as well?
Old Jun 27, 2005 | 07:12 PM
Slows2k's Avatar
Are both window switches plugged in? The circuit path requires both switches in each door to be plugged in.
You can power up the window motor with a battery.Make sure the motor is seperated from the rest of the circuit before applying power and ground. Switch polarity to change direction.
Old Jun 27, 2005 | 07:28 PM
S2kRob's Avatar
No, passenger skin is not on the car at all. Interesting that it would go down, but not up?
Must be the problem. Dodged a bullet on that one . . .
Old Jun 27, 2005 | 07:30 PM
Slows2k's Avatar
Plug in the other switch, I bet it works.
Old Jun 27, 2005 | 09:34 PM
revhi's Avatar
Is the window lock on? I did the same thing after I installed my speakers and was like WTF for an hour.
Kingkirk001
Nov 4, 2013 01:22 PM
volkdc2
Feb 14, 2012 10:50 PM
ghoward11
Jun 2, 2005 12:41 PM
S2k4mee
Oct 11, 2004 09:25 PM
dhayner
Jul 8, 2004 08:44 AM
