Passenger window problem
Old Oct 22, 2014 | 08:50 AM
MYang209's Avatar
Default Passenger window problem
This Past week I've been having trouble with the passenger window. It can't roll up or down from both switches from the drivers and passengers side, but when I use the roof switch I was able to roll it down and to roll back use I would have to flip the "passenger window lock" on the drivers side back and fourth. Any idea on what the problem is?
Old Oct 22, 2014 | 11:00 AM
jeffbrig's Avatar
If both driver and passenger switches are dead (no click), it's likely something to do with the window lock switch on the driver's side. I don't quite understand your statement about flipping it back and forth. Maybe it's not making proper contact and needs replacing?
Old Oct 23, 2014 | 09:00 AM
Car Analogy's Avatar
^, yeah, agree, sounds like lockout switch contacts are bad. Replace switch.
Old Oct 28, 2014 | 01:24 PM
S2Karlos's Avatar
You might be able to open the master switch (driver side) and just clean it up
Old Oct 28, 2014 | 01:33 PM
PureFunction's Avatar
having an issue with mine recently too. passenger side rolls down fine, but then it doesnt want to roll up. I do hear a click under the dash on the passenger side. after i try different switches like 20 times it eventually works. scared to roll my passenger window down now.
Old Oct 28, 2014 | 07:20 PM
windhund116's Avatar
If all the switches function fine (continuity test)... guess it would have to be the motor on the passenger side?
Old Oct 29, 2014 | 08:11 AM
S2Karlos's Avatar
Could also be that some wires are cut on the driver side, between the door and the frame of the car
Old Nov 1, 2014 | 03:49 PM
silver02s2000's Avatar
I have replaced both my window regulators but it would be best to replace switchesfirst sometimes tje passenger switch will get stuck causing it to go down but not back up from the master switch
verik07
Oct 15, 2012 08:52 PM
CasanovaJr
May 25, 2011 08:35 AM
Gernby
Jan 7, 2011 01:02 AM
ap1jay
Oct 4, 2009 10:20 AM
Ponch
Sep 24, 2007 04:13 PM
