pcv - excessive oil in intake
Old Feb 27, 2006 | 07:45 AM
vteconly's Avatar
Default pcv - excessive oil in intake
I know it is normal for pcv valve to deposit oil vapor which eventually collect in the intake and become gunks of oil. However, my pcv is ridding quite a bit of oil than what would be considered normal. I can put a paper towel next to it, drive around for 15 minutes and the towel would be covered with oil (not soaked).
Question is: What can cause this abnormal behavior from the pcv. Is some other line clogged?? A catch can would be a good idea but im afraid it might just mask the real problem. Thank you for your help.
-Hoang-
Old Feb 27, 2006 | 08:25 AM
S2kracka's Avatar
Excessive blow-by is a possibility and will occur as an engine wears. I recomend just getting a catch-can and watching how fast if fills up.
Old Feb 27, 2006 | 03:20 PM
Slows2k's Avatar
So you are driving with the PCV valve removed from the valve cover?
austincrx
Dec 7, 2016 06:44 AM
s2konroids
Dec 15, 2010 10:19 AM
dan_uk
Apr 8, 2010 08:39 AM
Boostedtaco
Dec 20, 2005 02:20 AM
ralper
Apr 17, 2003 09:46 PM
