Pic REQ...
i need a picture of someones clutch pedal... well the rod behind the pedal! I've been having a sticky clutch pedal so i decided to crawl under the dash last night and look around! what i found was a ton of black grease on the rod thats connected to the pedal... is this normal???
ditto... if the seal on your clutch master cylinder is out, the fluid will travel down the rod towards the pedal. If you pull back your carpet along the iinside firewall, you will probably see more dripping down also.
laserred02
Nov 28, 2012 07:12 PM
