Pic REQ...
Old Mar 11, 2010 | 06:21 AM
05berlinas2k's Avatar
Default Pic REQ...
i need a picture of someones clutch pedal... well the rod behind the pedal! I've been having a sticky clutch pedal so i decided to crawl under the dash last night and look around! what i found was a ton of black grease on the rod thats connected to the pedal... is this normal???
Old Mar 11, 2010 | 08:39 AM
Kyushin's Avatar
Banned
Means your master cylinder is gone, check the clutch fluid resivoir, I bet its BLACK. Replacing them is cake, so dont let the dealer scam for 200+ for labor.
Old Mar 11, 2010 | 08:45 AM
viets2000's Avatar
ditto... if the seal on your clutch master cylinder is out, the fluid will travel down the rod towards the pedal. If you pull back your carpet along the iinside firewall, you will probably see more dripping down also.
Old Mar 11, 2010 | 09:05 AM
street_ruler's Avatar
you will need flare nut wrenches or you run a huge rist of rounding off the fittings on accidents.
these wrenches are like 35 for a full set
Old Mar 11, 2010 | 10:05 AM
jyeung528's Avatar
i think most people just clean out the reservoir, bleed the clutch and call it a day
laserred02
Nov 28, 2012 07:12 PM
ntzz
Feb 10, 2011 01:22 PM
Rosso_Corsa
Oct 7, 2010 08:39 PM
refect
Feb 27, 2010 06:39 PM
8BALL
Jul 6, 2006 12:43 PM
