Pin for Crank Pulley?
Old Mar 15, 2014 | 09:22 AM
s2klariat's Avatar
Default Pin for Crank Pulley?
Which way do I insert this back into the groove on the crank and chain gear?
Old Mar 15, 2014 | 11:22 AM
MM3Kwolik's Avatar
The beveled edge goes inward toward the motor, and against the crank. Hope that makes sense.
Old Mar 15, 2014 | 04:49 PM
s2klariat's Avatar
Yep, thanks! How far in should it go?
Old Mar 15, 2014 | 05:13 PM
MM3Kwolik's Avatar
As far in as it can, the crank bolt tightening on the crank pulley will ensure it is all the way in though.
Old Mar 15, 2014 | 05:15 PM
MM3Kwolik's Avatar
BTW it's called a Key. More specifically a combination parallel and tapered Key.
Old Mar 15, 2014 | 08:44 PM
s2klariat's Avatar
Thanks! All buttoned up.
Chrisn01
Feb 19, 2018 12:56 PM
speedjunky01
May 15, 2013 03:36 AM
solomonster
Mar 7, 2009 02:56 PM
dans2k
Feb 5, 2007 10:07 PM
timg
Nov 23, 2006 06:05 AM
