pistons which ones ?
I know I can only run certain pistons in the factory block without getting sleeves. My question is what kind of after market pistons can I run in the factory block without getting sleeves? I know I can run factory piston so if that is my only option where can I get .20 over factory pistons. I am asking because I have some marks in my cylinder number 4 that may be too deap to hone out. I will put pictures up soon. Thanks guys.
looks like this is the same 4 cylinder scoring issue that many else have had. I guess this wouldnt be covered unless the car is under warranty, I wonder if I need a new block, I hope not, or sleeves there pretty pricey too.
It depends how bad it is, which is obviously impossible to tell from the pic. FRM cylinders can be re-honed withing certain limits but it is a time consuming and costly job and not one which just anyone can do. You will want to use someone reputable and who has experience of the FRM technology/requirements.
Take a look at what is involved in re-honing a FRM cylinder in the link below
http://www.hondatuningmagazine.com/tech/ht...ners/index.html
Anyone of the shops below should be able advise you on the best course of action or do the job.
http://bensonsmachine.com
http://theoldone.com
http://www.valleyengine.com
http://www.erlperformance.com
http://www.laskeyracing.com
