Please help...check engine light came on
Old Aug 22, 2003 | 12:47 PM
s2kwik09's Avatar
Default Please help...check engine light came on
Car was driving fine then I received no throttle response and the accelerator was depressed half way. Then all of a sudden the car jolts. It happened several times like that. Accelerator depressed...no response then away she goes. The check engine light came on next. The car seemed to drive ok after the light came on but I drove moderately. Has this happened to anyone? Any advice would be appreciated. Thanks!
Old Aug 22, 2003 | 04:11 PM
Nobody's Avatar
I had the EXACT same problem with my FZR just before the rectifier/regulator caught on fire (2 days after I bought the bike!).
Have you had any problems with the electrical/charging system?
Old Aug 22, 2003 | 07:51 PM
s2000guy's Avatar
First step is to take it to a mechanic and have them withraw the code. Without knowing what code was set it is almost impossible to help you.
Old Aug 23, 2003 | 11:31 AM
ExOdy's Avatar
Sounds like it could be ignition related.
Old Aug 25, 2003 | 11:08 AM
Gernby's Avatar
Former Sponsor
Go to an Autozone. They will pull the code for you.
Old Aug 25, 2003 | 12:40 PM
twohoos's Avatar
OK, I'll be the first to ask: MAP sensor?
Old Aug 25, 2003 | 08:09 PM
s2kwik09's Avatar
Fixed! It turns out the intake came loose from the throttle body. I guess I didn't tighten the clamp well enough. At least it was an easy fix and no harm was done. Thanks for your help!
Old Aug 26, 2003 | 05:41 PM
BL00S2's Avatar
Spammer
I would have thought that you would get more power from removing the intake but I guess the sensor read it as too much and put the car in limp.
CRUZPHX
Sep 9, 2016 09:49 PM
78kz650sr
16
Jan 21, 2011 12:34 AM
tadao916
Mar 2, 2009 04:47 PM
Congo
Dec 4, 2005 09:52 PM
