PLEASE HELP! In the middle of a spring install
Old Feb 12, 2008 | 07:16 AM
rugsr's Avatar
My God...it worked perfectly!
Why didnt the manual say to do it this way?!?!
Why would they say to pop the ball joint when this is soooooo simple.
Sweetness, ill have pics and vid up when im done. Look for it
THANKS!
Old Feb 12, 2008 | 07:54 AM
shamoo's Avatar
Glad you got it working. If nobody answered for you, I was going to chime in. I was surprised that this was an easier job than on my Civic/Integra.
Have fun with the rears though. It's a tight space back there in the trunk.
Old Feb 12, 2008 | 08:50 AM
SgtB's Avatar
Sorry for the bad advice. I focused on seperating the ball joint instead of what you where trying to do. Glad you got it together.
Old Feb 12, 2008 | 10:06 AM
rugsr's Avatar
its all good Sqt8
thanks
Old Feb 12, 2008 | 06:43 PM
Almostlude's Avatar
Originally Posted by f20kills,Feb 10 2008, 02:01 PM
The best way is to remove the two A arm bolts. Super easy and the shock will come right out.
This is the easiest way...... Otherwise the tool that you want to use is a pitman arm if you need to pop the ball joint
Old Feb 13, 2008 | 07:11 AM
Rusted_nailz's Avatar
Make sure you preload the supsension before you tighten all the bolts or the bushings can bind.
Old Feb 13, 2008 | 07:23 AM
nearwater4me's Avatar
How do you "preload" the suspension?
I don't think I went thru this step when I was installing mine.
Dan
Old Feb 13, 2008 | 07:27 AM
skibum's Avatar
I did it by placing a floor jack under the hub assembly and lifted it up to simulate the weight of the car on the ground. Then tighten to spec.
Old Feb 13, 2008 | 08:09 AM
rugsr's Avatar
Yea, i think i read this in the shop manual...but thankyou for reminding me !!
What The!?
May 18, 2018 06:43 AM
vteconly
Feb 25, 2011 11:47 AM
Spnshfirefighter
Jun 6, 2007 11:08 AM
YeLLoWs2knVA
Feb 13, 2004 09:29 PM
dp2580
Nov 12, 2003 04:25 AM
