Please Help with Problem
Originally Posted by Slows2k,Apr 5 2005, 03:19 PM
Does the car actually store misfire codes, or are you just after fixing a noise?
Ryan
Roja said the valves where inspected on his 1st post. If this is a hunt for a noise, Then I'd start inspecting the exhaust system for leaks. Otherwise my crystal ball is pretty cloudy on this one.
Ryan
Some brainstorming thoughts:
Did the dealers witness the "Putting" condition? If so, I'm not sure how they can say they couldn't find anything.
I'm assuming that the putt-putt sound is a misfire, but it's strange that your ECU isn't picking this up. You might want to hook the car up to an OBDII scantool hooked up to a laptop while you're running. You could watch all the parameters of the engine. Maybe it will catch something that isn't quite enough to trigger a CEL.
Is it possible that the putt-putt sound isn't a misfire? Could it be a rattle or a loose baffle in your muffler? Can you hear any noise coming from your catalytic converter? Can you rule out these potential problems?
I do not have a vafc or ems. I want a VAFC, but dont have one. I can rule out the exhaust cuz as i said, ive had 3 different ones. Thats all i can rule out. The dealer has witnessed the problem and still says its normal. Thats all I know.
Ryan
Ryan
As mentioned before, small exhaust leak possibly. Check out all the exhaust flanges with the car on, listen and feel for air. Did you replace the gaskets when you switched exhaust components back and forth?
Originally Posted by FraudulentNeon,Apr 6 2005, 12:11 PM
Small exhaust leak possibly. Check out all the exhaust flanges with the car on, listen and feel for air. Did you replace the gaskets when you switched exhaust components back and forth?
Ryan
