POP when turning right?
Old May 30, 2007 | 06:04 PM
mic_crispy's Avatar
Default POP when turning right?
I have a weird problem... whenever i make a right hand turn about about 20+ mph, i get a nice loud pop from the rear suspension... sounds like its comming from the center of the car. I am pretty sure its in the suspension cause you can feel it. DOesnt matter if the gas is applied or not so i dont think it has anything to do with the diff...
Any suggestions? My rear hub was replaced a while back when i hit a curb.. But this started about 2 months after that. I checked every bold that i could think of and made sure everything was tight... i took it to the dealership and they told me it was my springs on my coilovers not being seated correctly. I doubt this, cause ive had these for about 2 years now, and havnt touched the ride height.
Ive thought that maybe they didnt tighten the axle nuts all the way.. cause they did have to take those off, but from what i remember that made a diffrent sound..
Old May 30, 2007 | 06:29 PM
wmarc24@hotmail.com's Avatar
they tell me that your diff fluid needs changing asap.
Old May 30, 2007 | 06:39 PM
mic_crispy's Avatar
Whos they? I have never heard of diff fluid causing this... and its not a grinding noise by any means, nor does it happen when i apply gas...
Old May 31, 2007 | 04:07 AM
mic_crispy's Avatar
anyone?
Old May 31, 2007 | 11:09 AM
SpitfireS's Avatar
mic_crispy Posted on May 31 2007, 03:04 AM
Can you hit a curb, damage the hub and not damage anything else?
Are you sure nothing else was / still is damaged?
How is the allignment?
Lug nuts all tight?
Its not as simple as something moving around in the trunk.. is it
Old May 31, 2007 | 12:02 PM
mic_crispy's Avatar
Lug nuts all tight?
Well, to be sure i took my car to my local dealership and had them replace anything that they said needed replacing and they said it alighned within spec (as much as they could, car is slammed)..
I thought everyting was fine. until 2 months after and i started getting this popping noise. The dealership didnt want to help at all, and told me it was my springs not being seated correctly. I think that is bullshit, but just to make sure, im putting my stock suspension on tonight, and im going to take it to them tomorrow.
Jazaa
Nov 1, 2011 02:24 PM
LagunaBlu2k
Apr 18, 2011 06:54 AM
toniotran
Mar 11, 2010 03:07 PM
Unicron
Jan 21, 2003 03:13 PM
