Port matching
Old Nov 4, 2006 | 03:43 PM
Sideways's Avatar
Default Port matching
Make sure if you are adding a larger throttle body that you derive some benefit from it
and match the throttle body opening to the manifold. There is still roughly one mm left on this one to remove.
Old Nov 5, 2006 | 07:24 AM
John_Z's Avatar
Phil, can you post a pic where the extra material was welded then trimmed back?
Old Nov 5, 2006 | 08:03 AM
MugenRioS2k's Avatar
What brand TB is that?
Old Nov 5, 2006 | 08:12 AM
John_Z's Avatar
^BDL
Old Nov 5, 2006 | 09:09 AM
Sideways's Avatar
I think it has Anexoria Nervosa. It's lost over 2 lbs in all the right places and turned shiney.
New on the left and old on the right. You can see what was removed at the very bottom of the picture.
The 66mm bore on the right is maxed out with the passages.
Filling those openings resulted in the clean 68mm being hogged out to 70mm.
Old Nov 5, 2006 | 09:23 AM
John_Z's Avatar
Trimmed, shaved & filled in all the right places. I'll do this after my next mod
SCZ4
Apr 21, 2013 10:34 AM
biggyrap
Jan 12, 2013 03:01 PM
skunk2tony
Socal Swap Meet
Jun 10, 2010 01:07 PM
Startrek
Dec 25, 2006 09:27 AM
Si@Hendy Performance
May 12, 2006 02:11 AM
