Possible to decrease detonation with more fuel?
Old Apr 3, 2003 | 04:52 PM
RWD_RCKT's Avatar
If I have a LITTLE bit of detonation, but no way of retarding the timing, do you think I can just add more fuel?
Open to all opinions...
Old Apr 3, 2003 | 05:25 PM
fperra's Avatar
Enriching the mixture will definitely reduce or eliminate detonation, but only up to a point, after which detonation may actually increase. This was discovered by H. Ricardo in the early 1930s after extensive research and published in his book "The High-Speed Internal Combustion Engine". Assuming you are FI, the best way to overcome detonation at increased boost levels in to add water injection. I suggest you check out the Aquamist 2D system. Information on it can be found at http://www.aquamist.co.uk/ and http://www.ppeengineering.com/ .
Old Apr 4, 2003 | 12:16 AM
Maca's Avatar
Hi
The Vortech black box can retard timing and it appears to be re-writeable
MACA
blink962
Aug 28, 2012 03:38 PM
mayanh8
Sep 25, 2009 12:10 PM
ecxphilzy
Nov 11, 2006 08:51 AM
philauldridge
Jun 27, 2005 10:47 AM
AusS2000
Jun 12, 2001 07:46 AM
