Post your Alignment
Old Aug 13, 2008 | 10:52 AM
  #171
HUYS2200's Avatar
Tire pressure if a bit too high Chad, lower it down to 32-34.
Old Aug 13, 2008 | 10:55 AM
  #172
808_S2K's Avatar
I tried 34 all around but felt that the higher pressures were more responsive... We'll see again at the next track day
Old Aug 13, 2008 | 01:23 PM
  #173
124Spider's Avatar
Done for autocross on V710s:
AP2; with Gendron medium front bar, set at medium stiff; revalved Konis set full stiff in front, 3/4 stiff in rear; otherwise stock
Camber: -1.75 front; -2.50 rear
Caster: Max and even out
Toe: zero front and rear
I like this setup very much.
Old Aug 13, 2008 | 01:33 PM
  #174
Bob A (SD)'s Avatar
Left Front: -1.0 camber 4.8 caster 0.01 toe
Right Front: -1.0 camber 5.1 caster 0.02 toe
L&R Rear: -2.1 camber 0.21 toe
--Bob
Old Oct 23, 2008 | 04:58 PM
  #175
leo520's Avatar
can someone recommand me a nice set up for me?
i got j's racing kit 10 mm wider front fender, rear fender flared ..
with 18 x 8.5 front 225 40
18 x 9.5 255 35
Buddy club N + damper kit, around 1.5 inch of lower than stock.
my car will be most likely driving on the street, but a few tracks days during the summer times.
i will like more grips during the conerings, less under steer and less over steerings.
sorry for the bad english.
thx
Old Oct 23, 2008 | 07:04 PM
  #176
luder_5555's Avatar
my alignment looks like this / \
lol
Old Nov 17, 2008 | 05:13 AM
  #177
cracknut's Avatar
Picked up an '02 a few weeks ago (completely stock). Been doing trackdays for years in other cars but the S2k is a street car for now:
F:
camber: -1.2deg
caster: 5.6deg, 5.8deg
toe: 0
R:
camber: -1.5deg
toe: 1/8" in
My wife will drive it occasionally so I want to leave a little bit of understeer. I guessed on the relative camber settings. They might change to same F/R.
Old Feb 4, 2009 | 12:35 PM
  #178
sirbunz's Avatar
For reference/relevance purposes...
Here was my 2008 auto-x alignment settings on an '08 CR (recommended for auto-x and smaller/lower speed track). Keep in mind I prefer the S2000 with a mild oversteer. With these settings, I was able to be competitive and the Peru Solo2 Tour and Solo2 Nationals. With a better driver, these settings could accomplish much more on an auto-x level.
-Camber: -2 front -2.5 rear
-Toe: 1/16th toe-out front 1/16th toe-in rear
-Caster: Maxed
This was matched with the following suspension mods...
-Koni auto-x valved Koni Yellows (full stiff front, 50% rear)
-Gendron 1.375" FSB (set 3/6)
-Hoosier A6s 275/40/17 front & rear
For higher speed courses is would recommend going with a staggered tire setup (225/255+) and/or adjust the settings to induce more understeer.
Old Apr 8, 2009 | 05:09 PM
  #179
Rev9K27's Avatar
Just got mine done.
This is for autocross and street use using Bridgestone Potenza RE01Rs.
* Front toe - 0" toe out
* Front (neg) camber - -1.4 degrees
* Caster -- 5.5 degrees
* Rear toe (total) - .26" toe in
* Rear (neg) camber - -2.25 degrees
I tried to have the tech max the caster to over 6 degrees but he said the right front
could only max out at 5.5 where the left front can take a lot more caster. I'm wondering
if I have a slightly bent right front control arm.
Old Aug 18, 2009 | 03:44 PM
  #180
silvermonster's Avatar
can you guys give me some input on my alignment...I'm aiming toward occassion mountain runs/track days but don't want my tires to wear out so fast.
Here is my alignment:
Front:
Initial Setting: Final Settings:
Caster (L/R): 6.3/6.4 -------- 6.1/5.9
Camber (L/R) -0.4/-0.6 -------- -0.9/-1.0
Toe (L/R) -0.20/-.05 -------- 0.10/0.10
Rear:
Camber (L/R) -1.6/-2.1 -------- -1.7/-1.9
Toe (L/R) 0.25/0.25 -------- 0.30/0.25
Should I go with 0 toe in front? well let me know what you think of the alignment. Thanks.
Oh yeah, I have a 2006 AP2 with 225/45/17 up front and 255/40/17 in the rear. Tires are RE01. It is lowered on swift springs.
