Post your Alignment
Originally Posted by raisantos,Mar 14 2008, 08:23 PM
so i was at pepboy'a awhile ago(buying some cleaning stuff) and while looking around.. i happened to ask how much alignments are... the manager said 70bucks for all 4 wheels or 100bucks for a year of alignment, i didn't ask how often they will do it in a year, but that's beside the point... it seems like a good deal so i started asking more questions about it... my next question was, will they do toe, camber, and caster? he asked if i my car has stock suspensions... i said yes.. so they said they can only adjust toe in... i was under the assumption that we can adjust all caster, camber, and toe with stock "everything" on our car... the manager even asked another worker there.. and he replied.... no all honda cars he had worked only has toe as adjustable... i didn't argue anymore as i am not well versed in this things...(im still learning what caster does to your car as of the moment) so... my question is... what can be adjusted with our car if its bone stock???
Iduno about the pepboys by you, but I wouldn't go to the one by us if they paid ME to work on my car. If you go, I'd definately get a before and after print out of your alignment. Dont leave without one. Tell them you want one before they start.
2 Degree neg camber front
2 1/2 Degree neg camber rear
Maxed caster front
0 Toe front
1/4 Total toe in rear
Stock AP2 wheels with 225/255 RT-615
Auto-x and agressive street driving. KW V3's, K&N FIPK, Evasive Limited T1R 70mm single exhaust. Corner weighted to 50/50 cross weights 49.8 50.2 front to rear with my fat ass and 1/2 tank of gas.
Maxed caster front
0 Toe front
Originally Posted by B serious,Apr 30 2008, 01:02 PM
Front:
Camber: -2.6 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3 deg.
Toe: .25'' IN (factory)
Camber: -2.6 deg.
Caster : 6 deg
Toe: factory
Rear:
Camber: -3 deg.
I need some kind of specs to make it so that the camber is high enough that my wheels don't rub.
Originally Posted by Ro_Ja Boy,Apr 30 2008, 01:30 PM
When you say Toe: Factory, what is that spec?
If you're just trying to make shit not rub....just keep adding camber till it doesn't rub. Cut out your bumper in the wheel wells, crush your fender lips, relocate the bumper tab, etc.
Originally Posted by B serious,May 1 2008, 10:32 AM
0 rear toe? You sure? Also, the rear does not have a caster measurement.....
well I just had them set the camber and toe to specified settings.. I really just needed to max out the camber and i told them to set the rest to OEM.
Originally Posted by B serious,May 1 2008, 12:32 PM
Maybe that's why you can't get more than 1.7 deg neg. camber.
front:
caster +6.7
camber -1.0
toe 0
rear:
camber -2.2
toe 0
