Power Outlet Not Working
Originally Posted by davidc1' timestamp='1402636882' post='23201873
It's a common problem. Been discussed before a out 1,318 times at my last count.
You have to use some small hands and pry apart the plastic and "screw" it back in. Best thing is take out the panels and screw and glue it back in.
Originally Posted by gbozic' timestamp='1402677775' post='23202395
[quote name='davidc1' timestamp='1402636882' post='23201873']
[/quote]
I have checked it / cleaned it then I turned it on right after it and is still unable to work. On the other hand here's what the #9 fuse (10A) looked like after I pulled it out.
http://i58.tinypic.com/33w5ikz.jpg
Yeah that's the one I've been thinking all along, but still haven't been able to fix the problem. I've been behind there about twice within the last week and it still doesn't work, and as it's hard to see behind there I couldn't do much either. So I only unplugged and plugged the plastic in the cig lighter / power output. Do you have any tips how I could fix the circuit then?
Originally Posted by turbo_slug' timestamp='1402727187' post='23203165
[quote name='gbozic' timestamp='1402677775' post='23202395']
[/quote]
[/quote]
Uhh....that's one of the most obviously blown fuses I've ever seen!
See how the metal wire in the middle is melted, separated and the two ends are not connected?
Replace it and be on your way.
Originally Posted by gbozic' timestamp='1402798019' post='23203728
[quote name='turbo_slug' timestamp='1402727187' post='23203165']
[/quote]
[/quote]
[/quote]
Yeah now I realise how bad it is compared to other ones, thank you for the help and I'm about to head down now and buy new fuses to replace it!
Hopefully it was just the fuse, thank you very much!
Purchased these two ..
http://i60.tinypic.com/8ydifb.jpg
Now time to swap the old ones and in with the new, fingers crossed that it all works fine again!
And the result....
http://i59.tinypic.com/28vfuro.jpg
Both radio and power outlet working!!!!
Thank you for your help guys
