Power Outlet Not Working
Old Jun 11, 2014 | 04:56 AM
gbozic's Avatar
Default Power Outlet Not Working
Hey everyone,
Sorry if this has already been asked before but does anyone know how to fix the power outlet? I have an ap1 s2000 and it's been working ever since about last week it just cut out. There's no light indicating it's on, on my charger either so power is definately out.
I've gotten my hand in behind the plastic and fiddled around with it a little and still doesn't seem to work again!
Anyone know how to fix it? Would be appreciated,
Thanks,
Greg
Old Jun 11, 2014 | 05:25 AM
takasniper's Avatar
Can't you replace the outlet? I think you can buy just the outlet/hole part from honda.
Old Jun 11, 2014 | 05:43 AM
gbozic's Avatar
+ forgot to add my radio doesn't work at all now either, along with the power outlet. Everything else works fine but them two, hope someone can help!
Old Jun 11, 2014 | 05:44 AM
gbozic's Avatar
I could, but I'd rather try fix it somehow before replacing, if worse comes to worst I'll just go to a honda dealer and get it replaced..
Old Jun 11, 2014 | 05:59 AM
electricmarauder's Avatar
Did you check your fuses? Sounds like it's a blown fuse.
Old Jun 11, 2014 | 06:02 AM
gbozic's Avatar
I haven't checked yet as it's a tight squeeze through there ,I've only felt around with my hand for now. I'll check the fuses tomorrow morning and see what the outcome is!
Old Jun 11, 2014 | 06:15 AM
Looks like a #9 fuse (10A).
Old Jun 12, 2014 | 09:21 PM
davidc1's Avatar
It's a common problem. Been discussed before a out 1,318 times at my last count.
You have to use some small hands and pry apart the plastic and "screw" it back in. Best thing is take out the panels and screw and glue it back in.
Old Jun 13, 2014 | 08:40 AM
gbozic's Avatar
Thanks for the reply,
I've found the fuse I've taken it out and it looks like every other one, does that matter or should I just replace it?
Old Jun 13, 2014 | 08:42 AM
gbozic's Avatar
I've tried that just now for the second time tonight and it's still unable to work, I've taken it out / adjusted it a few times and turned the car on then off every time I adjusted it and it still isn't working, so it must be the fuse?
