power steering going in and out
Old Mar 12, 2010 | 11:25 AM
xasrielx's Avatar
Default power steering going in and out
my powersteering will work sometimes then quite working or sometimes it will only work when i turn to one side and not work on the other side.
anyone ever had this problem? if so can u tell me how to fix it plz?
Old Mar 12, 2010 | 05:01 PM
viets2000's Avatar
is your EPS light on?
Old Mar 12, 2010 | 08:15 PM
xasrielx's Avatar
only sometimes it's like my powersteering can fix itself. when it's not working the lights on and when it does the lights off.
Old Mar 13, 2010 | 05:13 AM
S2K1DAY's Avatar
Could be a short/loose connection/damaged wire that is barely hanging on and it's going on and off depending on which way you turn. Sorry, I don't know anything else about your problem.
Old Mar 13, 2010 | 08:21 AM
xasrielx's Avatar
alright well im not too worried about it right now cause i am naturally aspirated and it's not a HUGE problem. but i will definetly have to fix before i go forced induction
Old Mar 13, 2010 | 08:22 AM
xasrielx's Avatar
the previous owner did say it was the bearings going bad??? idk if that helps. i dont know much about the eps of the s2ks
Old Mar 13, 2010 | 11:17 AM
fatjoe10's Avatar
Hmm check the steering rack boots and see if they're ruptured. I just replaced an steering rack on an ap1 that completely failed simply because moisture got inside the electronics due to a ripped boot. His symptoms were very similar to yours for a few months until it eventually quit for good.
Old Mar 14, 2010 | 12:49 PM
viets2000's Avatar
If you have an EPS light, you'll have to have the code read, either by the dealer or by someone who has a scanner tool that does honda EPS.
BA4toAP1
Jun 10, 2021 05:50 PM
bsheep83
Mar 13, 2013 06:53 PM
silverstoneds2k
Jul 15, 2011 02:20 PM
street_racer_271
Mar 1, 2011 03:50 PM
trendy26
Feb 23, 2006 02:29 PM
