Problem with Clutch Disengaging
Old Jul 24, 2014 | 02:22 PM
xdreaming's Avatar
Default Problem with Clutch Disengaging
Hello, so for the past month or so, MY06 is becoming harder and harder to shift. As of today, it's almost impossible to shift. I have to force it in, and even then, sometimes it wouldn't go in. I would then have to turn off the car, shift to first, and then turn on the car. The past 2 or 3 times I've driven it, the clutch will act like it's half way engaged but will not stall out. I've read a couple other threads, and this one is most similar, if not spot on.
https://www.s2ki.com/s2000/topic/356...-on-the-floor/
I didn't want to resurrect that thread since it's from 06. I thought there might be some new information out there.
The most common recommendations are:
Master/Slave Cylinder need replacing
Pressure plate dragging
My AP2 has had the clutch/pressure plate replaced about 15k miles/1 year ago.
Only has 69k miles.
Anybody else have/had this problem? What did you do to solve it?
Old Jul 24, 2014 | 04:01 PM
RacerXI's Avatar
What clutch setup or pieces were installed? Have you checked under the dash for the infamous master leak down the rod? What color is the fluid in the reservoir? Is it full?
Old Jul 24, 2014 | 09:40 PM
xdreaming's Avatar
1. Competition clutch w/ 9? lb flywheel
2. No I haven't checked yet, but I'll be doing that shortly
3. It's a translucent dark brown
4. Yes.
Old Jul 25, 2014 | 03:30 PM
xdreaming's Avatar
Bump
Old Jul 25, 2014 | 03:49 PM
odb812's Avatar
Your fluid shouldn't be that dark. I'd try replacing and bleeding the fluid. There's a DIY writeup somewhere on here.
Old Jul 26, 2014 | 01:18 PM
RacerXI's Avatar
If you look up above your clutch pedal you'll see a rod coming through the firewall. Check for fluid at that rod and just above and right of your dead pedal. That'll let you know if your master is leaking.
rikhemi
Jun 3, 2018 01:34 PM
skyler2k
Nov 9, 2010 06:46 AM
jbell
Feb 2, 2010 08:03 PM
spazbaboon
Jul 19, 2009 08:36 PM
Ron
Jun 2, 2007 01:23 PM
