Problem, Don't really know what to call it!
Old Nov 23, 2005 | 07:30 AM
luderlm's Avatar
Originally Posted by pushinlsteg,Nov 20 2005, 03:11 PM
I just bought an 03.
I am having the same symptoms as you as far as it feeling like it wants to cut out, then feeling fine 2 seconds later, and the idle, if I tap the gas it drops to 200-300 rpm and vibrates for a second then goes back to normal...but this is only some of the time...(3-4 times I drove it)
That is exactly what my car does! I changed the spark plugs b/c my husband said it could possibly be that but It still does it.
Old Nov 23, 2005 | 08:33 AM
Reefwalker's Avatar
It could be your catalytic converter. If your plugs were fouled badly then unburned fuel could have caused damage to your catalytic converter by super heating it. This may be causing the bad smell that you are now noticing.
It could also be a bad O2 sensor. Super heating the exhaust could also damage this and cause it to send bad data to your ECU.
Have you checked for DTCs or is your CEL on?
Old Nov 25, 2005 | 08:04 AM
luderlm's Avatar
My check engine lights not on But now that you mention it whenever i go on a long trip in the car the check engine light always does come on but then it will shut off in about a day or so.
Also, I might sound dumb for not knowing this but what is DTC's??
Thanks for the help.
Old Nov 25, 2005 | 12:03 PM
Reefwalker's Avatar
Diagnostic Trouble Codes (DTC) are stored to tell a technician what is wrong with the car. If your CEL goes on, a DTC should be stored indicating what the problem is. Even if the CEL goes off, the DTCs are stored. You can use a scan tool to tell you which DTCs have been stored. They're available at Autozone and other parts stores.
Old Nov 26, 2005 | 08:17 AM
luderlm's Avatar
Oh Alright, Thank you!
aznoophi
Feb 27, 2010 08:25 PM
TheLoons12
May 4, 2007 02:45 PM
fltsfshr
Jan 13, 2005 02:36 PM
SaNgO5
Sep 21, 2003 03:12 PM
John David
Jun 21, 2001 05:54 AM
