Problem with Driver's Window
Old Oct 28, 2010 | 05:42 AM
TJF's Avatar
TJF
Default Problem with Driver's Window
Well, it was boud to happen. My S2000 actually has a (very very slight) mechanical problem after nearly 9 years and 52,000 daily driven miles.
When I try to "auto down" the driver's side window (either with the window switch or when putting the top down), the window goes down part way then stops. It acts as though it has hit a snag. You can physically hear/feel a very light "thunk."
Once it stops, I can close the window manually by physically holding the window switch, and it continues all the way down with no further drama.
It doesnt do it every time, but it does it maybe 30% of the time I roll the window down, and more frequently when I put the top down (probably 60%).
Any ideas?
Old Oct 28, 2010 | 05:50 AM
ChaseBaciles's Avatar
Any troubleshooting done? I'd pull the door cover to find if anything is obstructing the window. I believe in auto down if it catches a slight bit of resistance it will stop hence manual will drag it past.
Old Oct 28, 2010 | 06:17 AM
TruBluS2k's Avatar
my drivers window will not go all the way down unless i have the door open when i hit the roof button
Old Oct 28, 2010 | 06:57 AM
TJF's Avatar
TJF
No troubleshooting yet. I was hoping this might be common enough that someone would be able to say, "you need to replace _______ part." That way, I could avoid taking the door apart only to have to order a part and take it apart again. I could order the part, and only have to take the door down one time.
I am certain you are right. It is meeting enough resistance somewhere in its travel that it is causing the auto-down to stop. However, it isnt a real physical resistance, because the window finishes rolling down manually.
Any ideas?
Old Oct 28, 2010 | 12:06 PM
twohoos's Avatar
There was a TSB on early AP1s for the driver's window auto-down regulator; not sure if your '02 was affected but you might check the TSB archive here on the site.
garyg4761
Aug 13, 2018 03:55 AM
USAF_S2K
Jul 6, 2011 06:47 AM
mikdys
May 9, 2008 08:43 AM
theSILVERone
Oct 3, 2007 09:11 PM
George
Nov 25, 2000 03:00 PM
