Problem with Harbor Freight Siphon Pump Kit
Old Aug 23, 2007 | 08:34 PM
mew002's Avatar
Default Problem with Harbor Freight Siphon Pump Kit
I can't seem to siphon anythng with my new pump. I've ensured the the two outlets are tight and being used correctly but it still fails to siphon both differential fluid (Mobil 1 75w90) and water. I've noticed that the pump is not sealed air tight to the container. Could this be the problem? Thanks guys.
http://www.harborfreight.com/cpi/ctaf/disp...Itemnumber=3878
Old Aug 23, 2007 | 08:42 PM
FISH22's Avatar
make sure you have the tubes in the right spot. ie; the suction tube in the fluid.
Old Aug 23, 2007 | 08:50 PM
mew002's Avatar
Yeah I've ensured that the tubes are going in the correct place (tube near the pump is the intake tube, etc).
Old Aug 24, 2007 | 08:32 AM
neonextgenazn's Avatar
bump
Old Aug 24, 2007 | 09:10 AM
iam7head's Avatar
just get a damn hand pump, there's no glory in screwing in a screw with a knife.
Old Aug 24, 2007 | 09:34 AM
Triple-H's Avatar
I have had and used this pump for years, no problem, I will say though, it does take some work to get it started sometimes....
Pump more, pump harder, don't worry, your palms won't grow hair
Old Aug 24, 2007 | 10:00 AM
negcamber's Avatar
takes a lot of pumping to make the Harbor Freight one work.
Old Aug 24, 2007 | 11:49 AM
mew002's Avatar
Is it normal for there to be such a big gap between the shaft of the pump and the container though? At the moment, my pumps seems rather futile so I'm deciding whether to give warranty a call.
Old Aug 25, 2007 | 04:50 AM
jimmij's Avatar
You get what you pay for. I used mine one day on 5 cars and it is now trash. It will not even pump water.
killerbee_vr6
May 1, 2015 11:38 AM
99SH
Aug 28, 2014 11:47 AM
kaissi
Jul 25, 2011 11:03 AM
