"Properly" attaching replica AP1 lip
I recently purchased a replica OEM lip for my AP1 on ebay. The only installation hardware it came with was 4 screws. The lip does not have any brackets pre-attached nor did it come with any. I would prefer to mount the lip in a similar way to the real OEM lip which appears to use metal brackets on the lip along with existing bolts on the underside of the bumper. I know I will have to drill holes for the sides of the lip that attach in the wheel well.
Does anyone know of a source for either OEM or aftermarket hardware that would enable a cleaner install? Or perhaps a good "hardware store" solution with parts I can easily find at Home Depot?
I made a Video with my ebay lip how I attached mine worked perfect
https://www.youtube.com/watch?v=XeoDGribgqQ
Hardtopguy sells the OEM parts kit to mount the lip if you're interested in that.
https://hardtopguy.com/store/410.html
You'll have to mount the metal brackets to the lip yourself with rivets, but theoretically if you put them in the correct places you'd be able to install the lip in the same fashion as OEM.
I think i got lucky with my lip as most of the holes lined up really well; i only had to drill one of the small metal holders a bit
I also used doubled sided tape and you can buy the lip gasket for amazon
