PSA: Do not recommend AP1 Slave on AP2
Old Mar 22, 2025 | 06:25 PM
bad_driver's Avatar
Default PSA: Do not recommend AP1 Slave on AP2
You can call it skill issue or whatever, but I genuinely do not recommend this.
Not only does the slave wire hang too low because of it, you WILL have to grind down part of the hose.
The alignment pin length on the AP1 slave does not make it possible without doing such a thing.
After you do this, you need to be excellent with positioning the hose in order to maintain access for a 12mm socket.
It is much better to buy another AP2 slave cylinder and delete the CDV than to go purchase an AP1 slave cylinder.
However, after deleting the CDV, car feels great. Or the new clutch feels great. No clue.
Old Mar 23, 2025 | 09:50 AM
Slowcrash_101's Avatar
I have an ap2 engine and transmission and 10lb flywheel with an AP1 slave I didn't find any difficulty installing it.
Old Mar 23, 2025 | 10:24 AM
engifineer's Avatar
Alignment pin???
You ground down part of the hose ???
Old Mar 23, 2025 | 10:37 AM
bad_driver's Avatar
Originally Posted by engifineer
Alignment pin???
Terrible wording from me.
The small nib that protrudes
You grind this down and cut it to about half of its length. This is only needed because the AP1 alignment interface is not as long.
You could also install it without inserting it between the pins.
In addition, I feel like the slave line hangs too low. I had to do some slightly janky routing:
Old Mar 23, 2025 | 12:20 PM
engifineer's Avatar
oh ok that makes sense, I thought you meant an alignment pin on the cylinder itself and was confused
ceek732
Oct 13, 2017 03:19 PM
cinaibur
Apr 16, 2014 05:27 PM
woodburn
Aug 14, 2011 12:08 AM
R00567
May 16, 2010 12:32 PM
