Pulled 3 CEL Codes
Old May 1, 2007 | 05:02 PM
JoeS0Fly's Avatar
Default Pulled 3 CEL Codes
Recently I've had a CEL on and been through 3 batteries. The dealership pulled 3 codes out for me.
P1298 - ELD circuit high voltage
P0135 - o2 sensor
P0141 - o2 sensor
anybody have the same problem?
Old May 1, 2007 | 06:05 PM
gomarlins3's Avatar
What have you changed on the car?
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P1298 Electrical Load Detector Circuit High Input
Old May 1, 2007 | 06:38 PM
Slows2k's Avatar
If you have a Cold air intake, I'd be the wiring to the air pump control solenoid is cut by the drive belt. Both 02 heaters and ELD are powered on the same fuse (15A Fuse 6 under dash box) which is most likely blown.
Old May 1, 2007 | 07:04 PM
JoeS0Fly's Avatar
yea im running a k&n fipk, and invidia test pipe.
gonna check the fuse. i searched up some topics similiar to this, and the fuse seems to be the problem.
Old May 1, 2007 | 07:05 PM
Slows2k's Avatar
Fuse is blown for a reason. Check the wiring by the intake 1st.
Old May 2, 2007 | 06:42 AM
gomarlins3's Avatar
It's funny how these things always seem to be left out on the "HELP!!!!" threads.
Old May 2, 2007 | 07:24 AM
shamoo's Avatar
I also have a 0135 CEL with a totally stock 2007 with 8K miles. I think I heard that it was a TSB?
Old May 2, 2007 | 08:21 AM
Slows2k's Avatar
1 code is usually a different problem than 3 codes all with the same power source.
Honda isn't going to issue a TSB for every possible problem when troubleshooting already exists.
Old May 2, 2007 | 09:16 AM
gomarlins3's Avatar
It's under warrenty, take it to the dealer and have them fix it.
Old May 2, 2007 | 11:50 AM
JoeS0Fly's Avatar
fixed it. the problem was the fuse. blown. thanks for all your help!
and im off warranty now. the dealer gave me an estimate of 1000 something to change out both o2s.....when both of them weren't even broken.
thanks again!
cmc600rr
Oct 5, 2011 06:35 AM
GTI_JAY
Oct 17, 2007 08:24 PM
JLuda
Jun 13, 2007 07:28 PM
OCs2k
Jun 16, 2006 05:25 PM
phaze826
Jul 31, 2004 07:21 AM
