Pulled 3 CEL Codes
Recently I've had a CEL on and been through 3 batteries. The dealership pulled 3 codes out for me.
P1298 - ELD circuit high voltage
P0135 - o2 sensor
P0141 - o2 sensor
anybody have the same problem?
P0135 - o2 sensor
P0141 - o2 sensor
What have you changed on the car?
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P1298 Electrical Load Detector Circuit High Input
If you have a Cold air intake, I'd be the wiring to the air pump control solenoid is cut by the drive belt. Both 02 heaters and ELD are powered on the same fuse (15A Fuse 6 under dash box) which is most likely blown.
Originally Posted by shamoo,May 2 2007, 08:24 AM
I also have a 0135 CEL with a totally stock 2007 with 8K miles.
I think I heard that it was a TSB?
fixed it. the problem was the fuse. blown. thanks for all your help!
and im off warranty now. the dealer gave me an estimate of 1000 something to change out both o2s.....when both of them weren't even broken.
thanks again!
thanks again!
phaze826
Jul 31, 2004 07:21 AM
