Pulling diff
Old Feb 25, 2008 | 07:52 PM
airdawg's Avatar
Default Pulling diff
Help...I was pulling my differential tonight and had it already to go. But when I went to pull my half shafts (I guess thats the right terminology), I couldn't get them out. The would pull about 3" and stop.
Do I have to lower the diff first. Whats the technique. I just stopped and decided to ask before screwing up.
Old Feb 25, 2008 | 08:06 PM
Olegator's Avatar
Remove the outer parts of half-shafts from the rear knukles first (need to pull lower ball joints out), they they should come out no problem.
Old Feb 26, 2008 | 02:45 PM
airdawg's Avatar
Is there a clip inside that holds the inner shaft retained?
Can I access this instead?
Old Feb 26, 2008 | 03:14 PM
jack.tsu's Avatar
You need to pop the joint on the inside of your wheel. Theres a DIY thread with pictures somwhere
Old Feb 26, 2008 | 06:15 PM
S2KPUDDYDAD's Avatar
It can be done without removing the shaft....If you roll and turn the rear a little you can pop out the shaft. Once one is out the other will be easy
Old Feb 26, 2008 | 06:47 PM
IlleztImportz's Avatar
^something tells me puddydad did this before
Old Feb 27, 2008 | 05:31 AM
Out with the old and in with the new in under an hour that is in my car
I have had 12 rears in my car for testing.
DP's-s2k
Jan 29, 2009 09:37 PM
S-Turn AP1
Jul 27, 2008 10:17 AM
nightcrawler7188
May 28, 2008 02:01 PM
Boostaholic
Jun 7, 2007 10:10 AM
Stratocaster
Jun 12, 2003 10:18 AM
