Pulsating rubbing noise from rear
Old Jul 11, 2018 | 04:36 AM
Lochness Monsta's Avatar
Exclamation Pulsating rubbing noise from rear
Over the last 500 miles or so this noise has been getting louder little by little. I only heard it if I was really looking for it but now it's any time I'm going parking lot speeds, maybe a little more. It sounds almost like it's my left rear tire rubbing the quarter panel in rotation with the wheel. After looking at the car on a lift spinning the wheels on the lift, there was no noise and no indication of anything going on. The tires don't have any bulging anywhere, the CV boots aren't torn or anything, the wheel bearings have no play and don't make any metal to metal sounds, differential is quiet, etc. Has anyone else had the issue before?
I will upload a video later on today.
Parts List relevant to noise concern:
DSS 2.9 Axles
Puddy Mod 1 Differential
RPF1 17x9+45 on 245/40 BFG Sport Comp 2 Tires
5mm Spacer
Rolled/Pulled
Old Jul 11, 2018 | 06:27 AM
ISADE's Avatar
If it happens at low enough speeds, could someone push the car to move it while you're outside listening for the noise? Might help you pin point where it's coming from.
Old Jul 11, 2018 | 07:23 AM
Rolling through the shop you can hear it enough to know it's there, and several of us agree it sounds like a rubber sound; almost like a pair of old Vans shoes on a shop floor making that squeaking sound. None of us can pin point exactly where it's coming from when the car is on the ground and the noise disappears on the lift some how.
Old Jul 11, 2018 | 07:39 AM
LagunaPearlAP2's Avatar
First off, that's a great picture you have with the loch ness monster in an S2000 Secondly, Maybe with your on jack stands, you could try putting a jack under a secure location on the suspicious suspension arm and raising it to the natural ride height, and then rotating the tire? That way the tire would be in the same orientation it would be when you're actually driving. Do you think this could be related to the pulled fenders?
Old Jul 11, 2018 | 08:06 AM
That picture made my day when I found it, hands down my favorite S2000 picture yet. I plan on doing that tomorrow after work, it's the only day I can get the car on a lift and have a stiffener available to do so. I have been on the wheels, spacers and tires with the quarters being rolled/pulled how they are for about 1-1/2 Years/ 25k miles. One of the techs at my work keeps saying he thinks it is the brakes, but his logic doesn't quite sound right to me. The rear rotors on my S have been slightly warped for a little while now and they are gradually getting worse. He believes that the rotor is putting slight weight on the pad making the noise, however the noise is there in/out of gear, on/off brakes, accel/decel.
kgregg
May 22, 2018 12:40 PM
purplemonkeydishwasher
Jun 1, 2011 03:53 AM
s2k_Nut
Jul 1, 2010 04:57 AM
KAY'S
Aug 29, 2005 03:38 PM
9krevz01
Jun 23, 2004 08:52 PM
