Purschasing a turbo s2000
Old Aug 26, 2022 | 12:31 PM
  #31
sheesh's Avatar
Originally Posted by WhiteSSP
I just bought a turbo s2000 earlier this year, and there are a lot of little niggling issues I've been dealing with and fixing, and a ton more I have to fix. And mine was a running driving car that just didnt get driven that much anymore, but still got driven a thousand or so miles a year.
Be prepared to spend a lot of your time chasing down other peoples work and fixing it unless you got one of the rare ones that was built right from the start. Usually people that are meticulous about their vehicles dont leave them sitting under trees with a missing turbo or melted wires...
your right. If it was meticulously built and everything was done right, I highly doubt he’d leave it under a tree
Old Aug 26, 2022 | 12:32 PM
  #32
sheesh's Avatar
Originally Posted by rpg51
Run, don't walk.
When you say "built" engine, what exactly do you mean? Head, bottom end, both?
when you say run, do you mean away from? Or to the car?
i posted the engine parts list. Check it out
Old Aug 26, 2022 | 03:59 PM
  #33
silvio1522's Avatar
Not sure whether you're trying to convince some of the people here or yourself? If you think there's enough there in parts alone to warrant the price you're willing to pay, then go for it. Worse that can happen is you realize you're in over your head, and you part it out. Personally, I would do what others have already said and walk away, regardless of the parts list. Not worth the hassle to ME. Good Luck.
Old Aug 26, 2022 | 06:09 PM
  #34
rpg51's Avatar
Run away unless you are looking to get a car to spend years and tons of money to turn into a car that might be a lot of fun for a short period of time.
Old Aug 27, 2022 | 07:03 AM
  #35
umair's Avatar
It really does sound like u want it regardless of what myself and people have said. Like I said above 10k is what I would pay for it and set aside a minimum of 7k to fix it assuming the engine is good. If you buy it take it straight to a shop that knows s2ks and let them make it mechanically solid. After that you should drive it a bit to make sure its a halfway decent car. Finally, if things work out you can do the bodywork.
try to post better pics. Get some interior shots and pics of the whole car.
Old Aug 28, 2022 | 11:08 AM
  #36
maranelloboy05's Avatar
Originally Posted by sheesh
If the wheels are 3500, and all the parts that you can see that he mentioned are there, wouldn’t that convince you that the engine parts list is legit? Like the block even says “benson” on it.
everything on the list that you can see is there.
I'm saying maybe verify that stuff is real, you can buy fake TE37s for a couple hundred.....
Old Oct 16, 2022 | 11:08 PM
  #37
USN_MSC's Avatar
Looks a bit rough for $15K. Parked under a tree = someone gave up.
Old Oct 24, 2022 | 06:10 PM
  #38
turbojonn's Avatar
I don’t know: many of those parts are verifiable. Do a leak down and compression, verify the make of the header and only but it if you have a very good local tuner. He should have some sort of dyno sheet for it. Most don’t tune their own. If he has no no sheet and no idea of how to tune I would have doubts in the car. Definitely worth investigating though.
Curated Content Editor
Jan 18, 2021 04:35 PM
bjs2000
Mar 21, 2017 10:36 AM
ThanasiS2K
Nov 27, 2007 10:27 AM
