Question about check engine light.
Old Sep 19, 2003 | 10:37 AM
Road Rash's Avatar
Default Question about check engine light.
Once I take it to auto zone and they pull the error code, what do I do with the code?
Also if it's something simple like a loose hose will the check engine light go off by itself once the hose is fixed?
Old Sep 19, 2003 | 10:57 AM
The Unabageler's Avatar
you look up the code to see what's wrong
Old Sep 19, 2003 | 11:18 AM
xviper's Avatar
The code will "point" you in the direction of the problem. It may not "pinpoint" the exact problem in all cases. You still have to be a bit of a detective to zero in on what must be checked and resolved.
The light will go off on its own BUT it may take several driving cycles as in the case of a loose gas cap. However, to turn off the CEL, you must pull the "BACK UP" fuse under the dash. As shown here:
It is the 7.5 amp fuse near the top of the picture. With engine and ignition OFF, pull that fuse, wait about 30 seconds, put it back in - DONE!
If the "fix" did not fix the problem, your CEL will come back on.
Old Sep 19, 2003 | 12:45 PM
Road Rash's Avatar
Ahhh, Thank You...
Hopefully it's just the cap that caused it to go on.
Thanks again.
Old Sep 19, 2003 | 12:57 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Post the code when you get it. It will look something like PXXXX. I'll give you the code description.
steelers743
Oct 12, 2010 08:39 AM
johnquester2000
19
Nov 1, 2008 01:35 AM
623baller
Aug 19, 2008 11:14 AM
fallcityfisher
Apr 6, 2006 06:54 AM
gt2690b
Jul 5, 2005 10:59 PM
