Question About HighBeam
Old Sep 27, 2007 | 01:59 PM
albe's Avatar
Default Question About HighBeam
hey, do you have to take out your headlight to change the highbeam bulb?
Old Sep 27, 2007 | 02:07 PM
ryanfeldman's Avatar
it depends on how big your hand is. i was able to change mine without taking out the head light. there is the connector that is attached to the back of the bulb, and then there is a rubber piece that protects the light from dust, and of course the light is held into the assembly with a little 'U" shaped wire that holds the light.
Old Sep 27, 2007 | 02:31 PM
BondoBuilder's Avatar
Best thing to do is either a) take off the wheel and remove half of the fender liner so you can access the back side of the headlight, or b) take the bumper off, and remove the whole housing. It is a give and take...The clips on the fenderliner break easily, but the bumper can be a pain if you're working alone. Good Luck!
Old Sep 28, 2007 | 01:53 PM
Rdizzle's Avatar
No headlight removal required. Instructions from the owner's manual:
nazzri
May 7, 2014 01:56 PM
Nappyboy28
Mar 31, 2013 11:22 PM
smach
Apr 30, 2011 01:25 PM
vazelos2k
Nov 30, 2006 08:42 PM
Fed
Jul 21, 2004 03:20 PM
