Suggestions For Changing Parking Light Bulb
Old Jul 18, 2004 | 11:11 AM
Fed's Avatar
Fed
Default Suggestions For Changing Parking Light Bulb
Anybody have any tips for changing the parking light bulb on the front headlight without actually removing the bumper and headlight assembly? I tried following the instructions per the user's manual, but I can't manage to squeeze my hand in through the fender cover to reach it.
Old Jul 18, 2004 | 11:18 AM
dhayner's Avatar
I've done this once, and the instructions do leave you with little room for your hand.
Next time, I will take off the wheel and remove more of the fender liner clips. This should allow for better access and also not bend the liner so sharply.
Old Jul 18, 2004 | 01:20 PM
TriaXenginE's Avatar
i didn't even have to take the wheel off. just turn it in completely and take off the clips. wear gloves, cuz it gets messy.
Old Jul 18, 2004 | 08:01 PM
Fed's Avatar
Fed
I tried that, but still wasn't able to get the liner down enough. Guess I'll be trying to raise that side of the car. I'm trying to replace the bulb under the turn signal.
Old Jul 18, 2004 | 08:38 PM
you sure you took out ALL the clips? i've done this plenty of times on other people's car and i've never had any difficulty.
mind you there's a clip right behind the headlight housing that is the deciding factor on whether you're going to pull that liner far out enough.
Old Jul 21, 2004 | 03:20 PM
Mok's Avatar
Mok
there is also an 8mm bolt that you have to unscrew. that might make it easier.
Chazmo
Dec 13, 2021 05:26 PM
racer_X_123
Jun 19, 2011 04:07 PM
albe
Sep 28, 2007 01:53 PM
Kenpo_S2000
Oct 14, 2006 09:35 AM
8OOORPM
Sep 22, 2006 12:35 AM
