Question: About the Starter.
Old Feb 2, 2012 | 08:30 PM
y0itzCARL's Avatar
Default Question: About the Starter.
I had a question, What part does the starter grab onto, and Im not talking about the flywheel, is it called a ring gear? Because my starter has a hard time grabbing onto the flywheel, it spins freely after a few cranks, then maybe 10 seconds later after a few spins, it cranks over. Btw, I just got the starter replaced, so the teeth are fresh. Need help asap !
Old Feb 2, 2012 | 08:51 PM
franky's Avatar
the starter spins the flywheel which spins the crankshaft. Have you try and spin the crankshaft by hand to see if it spins freely? but you have to loosen the belt first.
Old Feb 2, 2012 | 10:11 PM
Kirpich's Avatar
did you mess with the tranny recently? maybe the one of the bellhousing bolts, that double as a starter mount bolts, is loose?
Old Feb 3, 2012 | 02:17 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
sounds like a defective starter.
The ring gear is a steel part and it is pressed on to the cast iron flywheel.
It would be HIGHLY unlikely if the ring gear were to come loose on the flywheel.
Old Feb 3, 2012 | 10:38 AM
y0itzCARL's Avatar
I dont thnk anything is loose, Im thinking the ring gear's teeth are worn. Thats why the starters teeth are not catching onto the flywheel. Does that sound right?
Old Feb 3, 2012 | 11:11 AM
DocS2000's Avatar
Those teeth are pretty hearty. As billman said, the starter is most likely junk. You hear the motor spinning, but not producing enough torque to turn the crank over.
Old Feb 3, 2012 | 11:16 AM
y0itzCARL's Avatar
Here's the video, you guys be the judge as to what it might possibly be.
http://www.youtube.com/watch?v=yLopFw-1hFw
Old Feb 3, 2012 | 12:16 PM
Billman250's Avatar
Top Answer: 1
Sounds like the starter is garbage.
It would be highly unlikely for the teeth on the flywheel to be damaged. They are very thick hardened teeth.
Old Feb 4, 2012 | 10:31 AM
y0itzCARL's Avatar
Hmm, okay I think im convinced the starter is shit, Do you guys happen to know if anyone is selling a used OEM Denso Starter? Im not trying to pay full price at the dealer, or possibly know a site, that sells the OEM starter for a goood but not too expensive price?
Old Feb 4, 2012 | 02:24 PM
franky's Avatar
pull out ur starter and take it to autozone or oreilly for a test.
Charper732
Aug 25, 2016 01:43 PM
llckll
Sep 14, 2010 06:59 PM
sworks
Mar 31, 2010 04:24 PM
RL7
Jul 2, 2003 12:51 PM
