Question on Billman's coolant bleed method
Old Aug 20, 2021 | 06:05 AM
Save the Manual Wagons!'s Avatar
Default Question on Billman's coolant bleed method
The method: https://www.s2ki.com/forums/s2000-un...bleed-1067218/
Hello. New here, new to S2000s. Am I correct in assuming I only need to bleed it until the heat gets hot, and NOT necessarily until no more air comes out of the front bleeder? I bled it 5-6 times including two trips around the block. Every time I shut the car off, there's a little hiss of air from the front bleeder. When I squeeze the upper hose, a little coolant comes out and then I close it. The heat is hot. Scorching hot.
Long story: I had my mechanic flush the coolant and they left the radiator cap open. By the time I got home (~15 minute drive) there was a huge mess under the hood and I lost almost a gallon of coolant. After letting it sit overnight I refilled it and bled it using Billman's procedure.
Old Aug 20, 2021 | 07:14 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If the heat is hot, you are good to go.
The engine is safe to run, and any residual air will be purged naturally into the expansion tank. Make sure the hose going from the rad to the tank cap, and the hose leading from the tank cap into the bottom of the tank, is intact. This will insure air is not pulled back in during overnight cooldown.
Old Aug 20, 2021 | 07:17 AM
Thanks Billman! At some point I'll PM you about a TCT. Still getting the rest of the car sorted first...
Old Aug 20, 2021 | 08:42 AM
Car Analogy's Avatar
This is why I diy. I hate paying someone to do something, only to have to clean up their mess, then pay for more materials, then do significant portions of their work over again.
Usually easier to just do it myself, usually way less hassle, always cheaper. Almost always superior results.
Old Aug 20, 2021 | 09:58 AM
Ugh, seriously. I DIY quite a bit, but this experience is one of many that might push me over the edge to do everything myself I possibly can. No one is going to care about the car more than me.
And half the time I can't even find anyone willing to do the work that I need done...
Old Aug 20, 2021 | 10:32 AM
kukudm's Avatar
Damn, all those mechanic fail videos on IG just popped up in my head after reading this. Honestly hate to hear this happen in an S2K
Old Aug 20, 2021 | 10:55 AM
Yes, it was very frustrating. But, all cleaned up now. And no harm done (I hope...) Temp gauge never got above 3 bars and it still runs normally, at least the limited amount that I ran it to do all the coolant bleeding.
dave_
Oct 15, 2014 06:16 PM
2001-S2k
Jun 11, 2014 06:22 PM
seansniper
Mar 16, 2013 07:05 PM
SpoolinU
Oct 23, 2009 09:33 AM
Scambo
May 19, 2009 05:50 PM
