Question on Koni shocks
Old Mar 12, 2012 | 12:58 AM
  #21
Jimmy Roadster's Avatar
Originally Posted by chubbychu
Originally Posted by glagola1' timestamp='1155921939' post='8372984
Just so you guys know, the distance you lower the perch on the shock does not equate to the distance the car is lowered. The car is lowered more than the perch difference. This is because the shock is mounted closer to the fulcrum or pivot point. Duh.
I'd guess that a half inch perch difference would result in somewhere around a 3/4 difference at the wheel.
The Koni's have a softer low speed compression than the stock shocks. This will result in more compression per a hit and when you couple this with a lowering, it's likely you'll smash the front of your car on driveways and stuff.
Have fun.
Back from the dead, but this guy was so right. Due to the softer low speed compression, I've been smashing the lower front half of my car into dips and what not.
I'm thinking of getting these and simply using the stock (03 AP1) springs. Would this still result in a lot of scapeage due to the higher amount of compression? I wouldn't think so since I'm still at stock ride right (less any minor change the shock swap would make). Would the Lee Grimes Spec autox valving help with this at all?
AP1_Silverstone
Dec 30, 2015 03:27 PM
galiff
May 20, 2011 11:21 PM
02_s2k
Mar 6, 2011 02:23 AM
SSSS2222KKKK
Jun 3, 2008 12:58 AM
pikkashoe
Jan 29, 2006 07:57 AM
