Quick Headlight Question
Old Mar 4, 2008 | 05:00 PM
TookayS2K's Avatar
Default Quick Headlight Question
Do you really need the middle bracket on top of the headlight?
Mine broke off and I was wondering if there would be enough support without it....
Old Mar 4, 2008 | 08:51 PM
Random1's Avatar
Without that plastic pin fitting into that hole top center the headlight can tip backwards. It will end up not being flush with the fender and will be pointed incorrectly.
I have not looked at one in a while, but it may be possible to repair by screwing in a stud (screw with no head) in place of the plastic pin. You can look and see if enough plastic is present to drill a hole and screw in a stud or screw with no head.
Old Mar 4, 2008 | 09:24 PM
TookayS2K's Avatar
Thanks for the suggestion, but I don't think there is enough plastic.
I'm thinking of using a piece of that bondo mesh to shape and use maybe some JB weld to give it support.
Any other suggestions?
Old Mar 5, 2008 | 01:06 AM
TookayS2K's Avatar
The bracket that is broken on my headlight is circled in RED.
Shouldn't the bracket circled in GREEN be enough to keep the headlight from tilting back?
Old Mar 5, 2008 | 04:42 AM
D_Spec's Avatar
Mine is broke and mine tilts back. It was a pita to get it to even shine in the right direction! I had to use a zip tie to hold it somewhat in place. Now its about as good as its going to get without buying anything. It still does not sit right with fender or the bumper (just a small gap in the corner closest to the hood), but I'm not blinding on coming traffic anymore!
hope this helps.
I know its not the best pic but if look good you can tell.
oh yeah, this is before the zipage!
Old Mar 5, 2008 | 11:01 AM
TookayS2K's Avatar
Before the zipage.. not too bad.
I'm going to try putting bondo or something in place of the bracket and than drilling in to keep it in place. I'll let you know how it turns out.
Old Mar 5, 2008 | 05:22 PM
D_Spec's Avatar
at night you could really tell.. I shined so high in the sky that it looked like a damn spot light at a grand opening!
Old Mar 5, 2008 | 08:11 PM
TookayS2K's Avatar
lol, I'm going to be attempting fixing to fix the bracket tonight.. I'll SHOULD be able to update ya tomorrow on fitment, etc.
TheDonEffect
Mar 24, 2014 09:32 AM
photown
May 27, 2007 11:26 PM
immaViLLaiN
Dec 28, 2006 09:06 AM
kenny
Sep 13, 2005 05:09 PM
yelloS2
Sep 3, 2003 06:13 PM
