Quick question concerning transmission fluid...
Originally posted by Emil St-Hilaire
On my last oil change,I managed to get the two quarts in but, about half a quart overflowed.
If you turned the car completely on it's right side, I'll bet you could get all 3 qts in no problem, maybe even a 4th. BUT, I wouldn't drive beyond the end of your driveway like that.
Actually the specific numbers are:
1.56 US Quarts for fluid change
1.71 US Quarts for overhaul
However if you look at where the drain plug is.....you can jack the car one way opr the other (sorry forget which and to drunk to care) and get the extra half quart in. So the correct answer is 2 quarts max.
Correct me if I'm wrong XV.......3 quarts?? PM me an please explain why you have not taken my place as Forum Moderator on this board!!!! I gave Shelli specific instructions (LOL)!
-PM coming.
Originally posted by wickerbill
That would be because the transmission only holds 1.6 quarts.
I've been using 2 qts. for about a year now.
The official capacity is 1.6 quarts according to my owner's manual. I agree that if you want to tilt the car you can get more in, but if you lower it down before putting the fill plug in 0.4 quarts will spill out and that's what I was addressing.
It has also been said that due to the high level of the tranny oil pick up tube, a slight overfill of about 200cc is a good thing. I'm not so sure a 450cc overfill is.
