quick screech at startup ?
Old Nov 29, 2013 | 04:18 AM
linnboi's Avatar
Default quick screech at startup ?
i hear a quick screech at startup sometimes in the mornings ... any ideas ?
Old Nov 29, 2013 | 04:31 AM
freq's Avatar
Starter over-run. No big deal, just a little unsettling.
Old Nov 29, 2013 | 06:25 AM
MR.T's Avatar
What exactly is starter over- run, never heard of it? I have the same noise.
Old Nov 29, 2013 | 06:40 AM
drobinson1692's Avatar
you're starter is just sticking a little bit in the cold weather. Very common on these cars, no need to worry - typically comes out in the cold.
Old Nov 29, 2013 | 07:06 AM
waleed786's Avatar
Could also be one of the accessory belts. Still no big deal if it only happens on start-up on a cold/wet morning
Old Nov 29, 2013 | 07:39 AM
freq's Avatar
Originally Posted by waleed786
Could be the accessory belt. Still no big deal if it only happens on start-up on a cold/wet morning
FTFY.
There is only one.
But more than likely the starter over-run that I mentioned.
Old Nov 29, 2013 | 11:33 AM
linnboi's Avatar
sounds right ..
Old Nov 29, 2013 | 12:03 PM
notaloafer's Avatar
+1 for starter over-run. Mine's been doing it for almost two years now and has had zero impact. Ignore it.
Old Nov 29, 2013 | 01:45 PM
elserdp's Avatar
Mine just started doing it this week and I'm glad you guys have lasted so long on it. I almost ordered a new starter.
'02 Silverstone Invidia N1, K&N Typhoon Intake
Old Nov 29, 2013 | 07:18 PM
CoolGuy094's Avatar
No need to order a new starter. This may just be the most common "issue" with S2000's in general. The general consensus is that its harmless, just a bit annoying in the morning.
