Quite a few things..
Old Oct 28, 2016 | 03:16 PM
turtleesss's Avatar
Smile Quite a few things..
So I've had my S2000 for about 5 months now and I gotta say I really love this vehicle. However there have been a few quirks with the car that have been driving me absolutely nuts. Whenever I press on the gas It does two things. A. When I'm at a stop and I put my car in gear and start to drive off, I hear this clicking sound at the back left of my car. The clicking sound repeats roughly 2-3 times while accelerating.(sometimes more if i really gas the car) I took it to my mechanic not too long ago and he said he didn't hear anything, but to me it was lound and clear. So I still had him Re-torque the axle nut. I went to pick the car up and it wasn't making any noise what so ever for the first few days, but then...click..click....tick, there it was again. Even sometimes when I take my foot off of the gas i hear a click. B. Whenever I'm driving in say 2nd gear and I shift into 3rd gear and I accelerate, my whole car starts to give me this rumble feeling. C. Sometimes when I start up the car i can hear a loud rattle from what sounds like the exhaust of the car. D. The clutch also feels like it doesn't have a definite engage point. E. Second gear has a rare habit of slipping out of place while I'm driving.
This is my first manual car and I'm pretty much self taught. Maybe I'm driving the car incorrectly but I don't think this is how a manual should feel or sound. But what do I know I'm still kinda learning.
Old Oct 28, 2016 | 03:23 PM
bgoetz's Avatar
Did you torque it per the DIY?
Old Oct 28, 2016 | 03:24 PM
Chuck S's Avatar
What rpm are you shifting at? (Yeah, I know.) I asked this 2 summers ago and 4300 rpm was recommended. Since I was new to the car (but not manual gearboxes) I thought I was getting put on as the "new guy" but that rpm works for my'06.
Was the axle nut torqued to the new, higher spec and re-staked?
What year car? Slipping out of gear was a maintenance issue years ago. Look in the library for the info.
-- Chuck
Old Oct 28, 2016 | 03:32 PM
turtleesss's Avatar
I shift around 4-5 k
Also not that i know of. He just told me he Re-Torqued it and gave it some new grease.
2004 Ap2
Old Oct 28, 2016 | 03:41 PM
Chuck S's Avatar
The latest recommendation for the rear axle nuts is 60° tighter than the original setting. That's one flat on a 6-sided nut. The nut bearing surface needs to be greased to achieve the proper torque. You may want to ask what he meant by grease and if the nut is one flat tighter than before. Easy to see if the nut is staked once the wheel is off.
-- Chuck
Old Oct 28, 2016 | 04:27 PM
dwb993's Avatar
It seems to me like you have a number of separate issues.
A) Re-torque the axle nuts to the proper torque rating.
B) Check your CV cups for wear and swap them if they are pitted.
C) Check all hangers and mounts, then check to make sure your catalytic converter is not coming apart internally.
D) You did not mention mileage and whether its original. Grease the clutch fork and check the master and slave cylinders.
E) Not sure about slipping out of gear, but it can be nasty when going into gear. Check the forums to see if anyone else had the same issue. If you haven't already, pull the shifter apart, re-grease everything and replace anything that needs replacing.
All of the above maintenance items have DIYs available on this site. You should start here: https://www.s2ki.com/forums/s2000-ta...first-1020648/
Old Oct 28, 2016 | 05:44 PM
freq's Avatar
If those wheel bearings are already screwed up then retorqueing the axle nut isn't gonna help. The damage is already done.
What dwb said about the regrease but why not change the trans fluid too.
Old Oct 28, 2016 | 05:57 PM
turtleesss's Avatar
Yeah i probably will replace them if this dosen't fix it.
When I took it in he changed all the fluids.
Luke01
May 19, 2011 06:38 AM
milevchuk
Sep 6, 2007 04:16 PM
DarkEarth
Apr 1, 2006 12:41 PM
ace8726872
Dec 4, 2005 05:17 PM
lostsol
Nov 29, 2002 08:37 AM
