Radiator fans not working
Any idea why the cooling fan & AC fan would not be running?
I've also checked the cooling fan fuse, it's still good.
Just swapped out my radiator today to replace another OEM one but now my fans aren't running. All 3 connectors have been securely plugged in and clicked. Engine was warmed up and heater on max with fans on high, no response from the fans and it was just blowing cool air.
Any help is appreciated, thanks!
Just did a coolant change and air burp this weekend - when I first started burping the system, I found that the radiator fans won't come on when there's still a significant amount of air in the system. Something about trapped air preventing the thermostat from opening? My scanner showed temps of 235* so I shut it down. After doing some more burping the fans would cycle on at about 214* and cool the car to 194*, but my heat wasn't hot hot yet. It took quite a bit more burping to purge all the air and for the heat to get really hot. I highly recommend the Lisle spill free funnel, makes burping really simple.
Took a risky move.
Warmed the cold engine up with the radiator cap off until operating temp, turned off the car, cap back on, started car and went on a 5 min drive. Luckily, no overheating but unfortunately, no heater still. I'm not sure what to conclude from this.
Any help is appreciated, thanks.
To properly bleed the car, you can burp but ultimately you have to use the bleeder.
To burp the car take off the rad cap, then just stick a spill free funnel in the radiator, and run the car. Just keep squeezing the top radiator hose over and over and over and over again while the car is running until you no longer see bubbles in the coolant that has expanded into the funnel. Then when you finish use a hand pump or turkey baster, and transfer the fluid in the funnel to the overflow bottle, and cap the radiator. Now after the heater is blowing hot air, run the car for a bit more, then shut it off after the fans come on. With the car off, squeeze and hold the upper rad hose, and open the bleeder on the head with the hose still squeezed, if you see coolant spurt out right away close it right away. Never unsqueeze the upper rad hose with the bleeder open, you will suck in air. If you have air in the system the car will drive fine and then it will suddenly overheat and then you'll be up
creek without a paddle.
creek without a paddle.Trending Topics
joes sled 2000
Apr 15, 2012 09:44 AM
